Old 01-08-2011, 04:54 PM
bobcowan's Avatar
bobcowan bobcowan is offline
The F-10 is fairly simple. It has a main fuel map based on rpm and TPS. There are a bunch of modifying mapes available. I use only 3 modifying maps: Coolant temp, air temp, and altitude. I don't even use the accelerater map or WOT map. All three that I use were at baseline, which means no modification to the base map.
It's odd that the recorded IPW is exactly 2x the map IPW. I found the same thing at other points in the map.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
