Old 01-08-2011, 05:52 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Default Part # for Centerforce Clutch and Pressure Plate..Help
Well I've removed my hood, picked up my engine hoist, took lots of pictures, drained fluids, etc. Oh yes, the engine tranny swap has begun for SPO 2423. Could someone provide me the part numbers for the Centerforce dual friction clutch, pressure plate, throw-out bearing and pilot bearing for a early Ford 351w block stroked to 408 supporting 550+ horsepower at the crank? Transmission is a TKO 600. I tried using the technical support for centerforce via email with no response. There are so many part numbers and types and I want to get the correct components. Would you recommend the 10.4" or 11" diameter recommended? I'm open to other clutch packages if they have had a good experience. Car will not be tracked. I just want the car to be a bit nasty Thanks
