01-09-2011, 12:32 AM
AZ
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Think twice before bolting down.....
Originally Posted by csx4910
Thanks. I forgot about the rolelrs but I think mine will have that as well. That would help to make sure it is in the right place before bolting it down.
Thanks
Ron, make sure you know if your garage has stress tension bars installed in the floor or not. If they are installed and you drill thru one it could cause you some major issues. I installed my Greg Smith 4 post lift over the holidays and have the rollers that come with the lift. These rollers are really great since they give you the opportunity to move the lift whenever you need to. The rollers are removable and the lift just sits there. I have moved the lift twice since getting it so I could fine tune the location for my other car. Hope this helps. Cheers, John, AKA tin-man
Be well, drive fast, live long
