Old 01-09-2011, 10:50 AM
blykins blykins is offline
Originally Posted by joyridin' View Post
My Centerforce works well also, but I would never buy one. My brother works at Luk. Seems like a cheap way to make a supposed high performance clutch. They all come off the same stamping line.
There's really not that many pressure plate manufacturers in the US....LUK and Valeo provide a lot for different manufacturers. Valeo makes most of the pressure plates for McLeod and possibly RAM.
However, it's what you do with the pressure plate that matters. If you find the right one with the right static pressure, then combine it with the correct disc material for your application, you won't have any issues. The problem with the Centerforce stuff is that their counterweight system doesn't always work and the discs they use are nothing special.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
