Old 01-10-2011, 07:42 AM
JUS BIT JUS BIT is offline
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
I stock the HID kits. ($185 plus shipping) They include the ballast for both lights, new housings, and the 6000k bulbs. It is the best upgrade I think you can do for these cars. The visibility at night is incredible. You will never use the high beams again.
These H4 bulbs have HID low beams, and regular halogen high beams. You'll never use the high beams again since the HIDs are so bright, but the high beams are there to pass inspections. They do not use both HIDs for low and high because they draw too much amperage and an entirely new harness with relay has to be installed.
They are relatively easy to install. Just take out your sealed beam light, cut a small hole in the light bucket for the new harness, and mount the new housing and HID bulb. Then you plug the ballast to the new harness and mount. It's about an hour job max and it's all plug and play.
We have used a few different ones out there, just be aware of some of the stuff on Ebay, some of them fail often. Let me know if I can help.
James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
