Old 01-20-2002, 04:20 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Default Hydraulic clutch kit
Thought I'd pass this along to those of you looking for hydraulic clutch kits for your big block from a Mustang shop in SanDiego, johnsmustangs.com.
"John Da Luz"
Items included in the kit;
Master Cylinder
Firewall reinforcement Plate
Slave cylinder or Hyd Bearing
Fluid Reservoir
High Pressure Line
Push Rod and Bushings (for slave style kit)
Mounting Bracket (for slave style kit)
Grade 8 Mounting Hardware
Hyd Fittings
Prices for kits range from $385.95 to $505.95 depending on the type of trans and kit. The bearing style kits are
priced at $505.95 and the slave style kits range from $385.95 to $445.95.
We have kits for T-5, Toploader, T-10, Richmond 5 and 6 speeds, Tremec 3550, TKO and T-56.
Thank you,
John
