Old 01-11-2011, 08:35 AM
nymathboy nymathboy is offline
No problem.
You'll probably find that the Victor Jr. makes things a little "soggy" down low with only 351 cubic inches pulling through it. It takes more rpm to get the larger amount of air in the intake to get moving and build velocity.
The dual plane intakes should help out quite a bit and still offer good performance with better heads/cam. (Go with the AFR's....)
Which AFRs...The 185s or the 205s ?
