Old 01-11-2011, 02:36 PM
Tommy's Avatar
Tommy Tommy is offline
Much good advice above. The way I see it, there are three mechanical problem areas where you don't want to drive the car even a short distance. They are problems with steering (i.e., suspension, wheels, steering, loose seat), brakes (even and reliable), and fire (electrical shorts or fuel leaks). Engine problems that could leave you stranded in an intersection or on a dangerous road could also be dangerous, but might be tolerable just to get home under the right conditions. Most other problems cause inconvenience at worst. Be sure you've got the big three under control and you should be OK.
Tommy
Previously owned EM Cobra
