  #22 (permalink)
Old 01-12-2011, 05:24 PM
dlampe's Avatar
dlampe dlampe is offline
If you had popping while at cruising speed and not on deceleration or acceleration, you had a spark issue which you probably solved. By 2000 rpms you are well into the transition and the emulsion tube is starting to flow. I am running this setup,
idle 65
holder 100
Main 170
air corrector 180
F7 tubes
.50 bypass
40 chokes
Hydo roller cam .655 lift, 246 dur @ .050
on a 482 side oiler.
There is a hole between the main jets where you can see the float. My floats are 8.5 mm down from the top surface.
High Maintenance Racing Team
Run & Gun 2003 - 2013
