Donunder & 750hp, If you compare the OD of the headlight trim rings at their widest point, you should find the Arntz to be .25" larger in diameter than the one on the RMC.
Approx OD Arntz = 8 3/8"
Approx OD RMC = 8 1/16"
Depending on the trim ring manufacturer, the Arntz trim ring should have a fixing screw thru the trim ring under the light lense and a pressed dimple on the top of the ring. The RMC is just a push on interference fit trim ring with no fixing screw and no dimple. (although some folks do drill the RMC trim rings).
Love the red car and love the green car Craig posted. Narrow hips and wire wheels. woohoo.
