Thread: Arntz vs RMC
Old 01-18-2011, 04:52 AM
Rebel1 Rebel1 is offline
Originally Posted by Outwest34au View Post
Interesting fact about the trims. Did they make them specially for Arntz? Can I assume they may not be the usual pommy sourced.
No special Arntz versions and they are both standard pommy source.
The most common 7" headlight trim ring used is the standard MGB/TD/TF/MINI/JAG versions and this fits most replicas. However, there is another called the cobra trim ring. It is off some Pommy some thing or other. Maybe Healey (not sure).
Both types are for the standard 7" light but the cobra trim is too large in it's widest dimention. That's the part that lines up against the body.
See here: http://www.s-v-c.co.uk/lights_head.html
The Arntz I suspect uses the actual cobra trim ring at 8 3/8 OD.
