Thread: DRB 540 build
Old 01-18-2011, 04:16 AM
paul68's Avatar
paul68 paul68 is offline
Cobra Make, Engine: DRB 540
Default fuel pump mod
This is the sedan pump with the ute fuel sender float attached.You need to remove the float arm(i used 2 large screw drivers to leaver it) and wiring from the ute pump and attach to the sedan pump, shorten the float arm so as not to foul on the tank baffles.BE VERY CAREFUL of copper sender.
Didnt need spacer ring as per photo.
