Old 01-18-2011, 08:48 AM
Curt C.'s Avatar
Curt C. Curt C. is offline
Cobra Make, Engine: Classic Roadster; 351W
Is your car a solid axle or IRS? If you are running a solid, you can tighten the rear end up via a larger sway bar too. Its a lot easier to tune via sway bar changes than springs and may give you and indication you are going in the right / wrong direction before buying more expensive pieces.
