Old 01-18-2011, 12:50 PM
Ant Ant is offline
Default How to choose oil viscosity
My engine builder recommends a 15-40 wt oil for break in and uses oil like Schaeffers 705 for racing.
I have spoken to oil chemists and they state a 20-50 oil running at the correct temperature such as the Schaeffers or Penrite gives a better protective film for racing or at least a bit of built in insurance. My car has an oil tank heater so I believe that takes care of any cold start issues, also Schaeffers 705 racing oil has excellent cold start features. We in NZ have generally a colder climate than Aussie or California etc so I wouldnt be against using a 40wt oil. My engine has been dynoed on Chevron Delo 400 15-40, I spoke to Chevron and this oil is specc'd for gasoline engines as well as diesel so in effect Joe Bloggs on the street may say its a diesel oil in actual fact he doesnt know what he is talking about!
I am intending on using Schaeffers 705 as being a race oil it is also suitable for extended oil changes which I wouldnt do, plus it has the good zinc level.
Here in NZ Grant Brennan has tested different oils in a RACE ENGINE and has come up with the results below relating to the enclosed weblink.
Schaeffers 705 Racing Oil 20W50 is the highest quality semi-synthetic multigrade oil for high performance racing engines available. It will give a competitive edge through increased horsepower and engine protection. It is specially formulated to reduce friction and wear, increase engine efficiency.
"We have tested Schaeffers against the competition and the results are conclusive. We wouldnt run it in our race engines if we didnt believe it was the BEST product available". GRANT BRENNAN - Brennan Racing Ltd
http://www.bernoil.com/resources/Bre...estResults.pdf
My only experience is with Valvoline SAE 50 and all that did was cost me oil pressure, I changed to Valvoline synracing 15-40 and that still dropped oil pressure down to 35-40psi. I was recommended Castrol RS 10-60 and found this oil to be extremely temperature stable etc in my F5000 engine started off 70psi cold and NEVER went below 60psi on the hottest day, nowadays I feel the 60wt is a bit heavy and make cost a little power, the question is would you actually notice it?????
Also with my Ford Laser 1.3 it has done 490000K nothing other than 10K oil filter changes, belts and plugs on mineral 15/40, car isnt garaged with frozen over winter starts. That tells me the oil is getting to where it should be on cold startup and the only difference 5-30w may do is make it slightly more economical. Some forms of racing use light weight oils probably due to the rpms and it wont affect the short life the engines have. I have to go with oil manufacturers recommendation for larger older tech engines and they generally recommend at least a 40wt hot oil.
A J. Newton
The 1960's rocked!
