Thread: Side Pipe SPL
Old 01-22-2011, 08:50 PM
Rare Iron's Avatar
Rare Iron Rare Iron is offline
Originally Posted by Machiavelli View Post
Eric (Rare Iron),
Your chambered flow-thru exhaust makes sense, specifically when dealing with the sound reflection aspect of your "stamped" outer muffler shell to block the leakage from the inner 3" (or 2.5") diameter inner tube. I have also looked at everything on your website, all pictures show a head-on view of this "stamped" muffler concept. Just curious, because sound radiates 360within any chamber, and the annoying higher frequencies like to bounce on metallic surfaces, do you also stamp the opposite sides of your "powersticks" (not visible in the photos)? If not, why not? From where I sit, as long as you maintain that inner 3" (or 2.5") diameter clean flow-thru path, you have double the capacity to block those unwanted higher frequencies by stamping both sides? (Maybe they need to be staggered in some way, but you get the idea)
Machiavelli, the Powerstick muffler is a chambered muffler - Cobrapacks are smooth & not chambered (you probably already know this). The crimps in the outer shell of the chambered mufflers create a soundwave anomaly which "tune" the exhaust - they give the exhaust a very unique sound. I'm not sure what you are asking about my crimp design. I crimp them at 12:00 & 6:00 positions, with relief areas at 9:00 & 3:00. Other chambered designs crimp at all 4 positions. My design pattern gives mine a different sound, as well as my perforation pattern in my cores. All combine to make them what they are.
COBRAPACK Mufflers
www.classicchambered.com
