Old 01-22-2011, 09:01 PM
boxhead's Avatar
boxhead boxhead is offline
Stumpeater, when you say "I have got it working by removing wire"
Are you saying that the dash light is on on your car until you remove the wire?
If so then I personally would say you have wired the switch correctly, and infact the switch has been tripped, to reset the switch, it is just a simple case of removing switch and pumping brake pedal a couple of times, then refitting switch.
No fluid should come out (if it does then there is a fault inside your master cylinder).
Forgive the rough diagram.
Originally Posted by stumpeater View Post
Thanks Lionel & Merv for posting that schematic, very handy. I have one query, on the warning switch, there are 2 pins, I assumed they were opposite sides of the switch and hooked up one to earth and the other to the warning light, but it turns out it is actually an earthing switch, and the pins are joined inside the switch body, where does the second wire go to when used on the Falcon? I've got mine working by removing the earth wire.Thanks.
Cruising in 5th
