Thread: Oil discussion
Old 01-23-2011, 08:22 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by RallySnake View Post
I am having much better performance with the Shell Rotella 10/40. It runs just as good and doesn't leak everywhere. The oil pressure is much better, too.
I believe that it continues to have zinc in it which helps with that camshaft wear issue.
RS
Diesel oils are all CJ now. I havn't been able to find a CI oil anywhere. The Cj oils have about 25% less zinc in them, because newer diesel engines have a cat. So it doesn't have the zinc a flat tappet cam really needs.
If you have flat tappets, you need to find something that has high zinc levels, like Brad Penn or RP XP. Or use a zinc additive.
My diesel engine has flat tappets, so it gets 2 bottles of Comp Cams break in additive with every 12 qt oil change. The cobra uses standard Royal Purple, and gets one bottle for every 11 qt oil change.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
