Hi Boxhead
AN832-6J,-8J are straight bulkhead fittings and AN837 series are 45Deg bulkhead fittings they come in sizes from -3 to -16. You can get them in steel, stainless and alloy.
The only problem with using SS tube and alloy fittings the flare is a lot stronger than the fitting so if you dont have a perfect flare it will leak.
