Old 01-26-2011, 09:28 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hey T,
You did mention she squeals at start up but does engine temp seem to matter? Does starting after warmed up still make noise? Aluminum engines tend to get a little taller when hot and tighten the belt a little bit.
Changing position of a driven component (alternator maybe) allows more wrap or contact surface area of the belt. A small change of angle on driven side makes a big difference. I would guess the alternator pulley is source of squeak since it has resistance and the smallest belt contact. Drilling small holes in pulley adds a little traction and only adds wear to belt if it is still slipping on pulley. Happy hunting.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
