Old 01-26-2011, 04:10 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Smile Surging / misfiring with MassFlo
Just thought I would share a problem solved with my Mass flo kit.
Engine would run at idle and at wot but would surge at low throttle opening while driving.
I have a large oval COBRA air cleaner which sits above bonnet line and below scoop.
Problem was airflow entering filter and rushing across maf meter causing a disturbance therefore throwing out its readings.
I taped the front of the filter so air couldn't rush in there and problem solved...
Only mentioning this incase someone else is also tearing their hair out trying to find out why?????
Now off to the dyno!!!
