Old 01-26-2011, 05:08 PM
Merv and Sharon's Avatar
Merv and Sharon Merv and Sharon is offline
I know how you feel Bob. I had the same experience. Happy to lend you an EEC. I also found this below, as it applied to mine - I had a manual harness and an auto EEC (A9P). You are sure that you have a manual harness? The A9L is the manual EEC. It all centres on pin 30:
"Manual/Automatic EEC Code Wiring Differences
There is a hardware difference between an auto processor & a manual processor. The difference is because of the way the NDS [neutral drive switch, manual trans] & the NSS [neutral safety switch, auto trans] are wired. They are both wired to the same pin#30 but the auto trans wiring grounds the pin to the starter solenoid & the manual grounds to signal return, during crank mode there is a voltage spike sent to pin-30 so the auto trans processor has a diode on pin 30 where as the manual processor doesn't, most of the time this won't cause a problem unless you get into a prolonged crank condition.
I've been warning people about converting an auto to a manual and using the manual EEC with the auto wiring harness; those that want to convert their automatics to manuals, and swap the ECM, need to clip the wire going to pin 30 or else the ECM will fry."
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
