Thread: Bellhousing
Old 01-27-2011, 08:55 AM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
(an excellent use of this post as an advertising forum, I commend you.)
I saw the 22 and 24 lbs weights on the QT web site. Then I noticed that is doesn’t matter what Mfg, motor or trans config. the weight only varies a few lbs.
I figured based on QTs history of extra loose presentation of technical data, Id better call Summit for an infusion of impartiality.
They must use really heavy shipping boxes....
Interestingly, I found that Lakewood also sells a series of “transmission adapters” that are similar to the non SFI QuickTime as they lack all the lower bolts. However, Lakewood goes to great lengths to distinguish that while better than a cast alum housing they are NOT safety housings. Hmmm who knew….
