Originally Posted by strictlypersonl
On an early car we've got in the shop right now, the shift lever is offset quite a bit toward the passenger's side.
Exactly, for the toploader. The Tremec hole, if it is symmetrical around the shifter, will be more toward the center of the tunnel and a bit forward. When I did this conversion, I just blanked the original hole off with a riveted aluminum plate. Then set the tunnel down on the Tremec stub (in neutral) and tap with a mallet to mark the center of the new hole.
If you do the blanking plate from underneath and fill with a little Bondo on top, you can't tell once the carpet is laid. Of course a perfectionist would fabricate a new top panel for the tunnel. It's just a flat sheet of alum.
Sam
