Old 01-29-2011, 07:14 PM
madmaxx madmaxx is offline
1) Brake Caliper bolts
2) Half shaft bolts/nuts
3)Bellhousing bolts
4) drive shaft bolts/nuts
5) grease ball joints
6) Probably need to tighten belts after a couple hundred miles if they squel
7) Retorque intake manifold bolts, exhaust header bolts, valve cover, water pump, distributor hold down.
8) if spinners not saftey wired put a black mark on spinner and wheel so you can visually check if they have moved.
9) you will need to do #7 every 500 miles until 1500 miles.
10) If you get the car delivered with the plastic oil line to oil gaugeDO NOT ACCEPT DELIVERY get the braided line. I replaced mine and now I have no dripped any oil in a month from the engine, a first.
