Old 01-30-2011, 08:57 AM
dlampe's Avatar
dlampe dlampe is offline
I would ask/advise you buddy with the Kirkham to get some new tires. I'm sure the tires he has are road race slicks, not drag slicks meaning that it take a while to heat them up. They will be "slick" on the drag strip. The other point to consider is the age of his tires. Slicks will dry out. It is a legitimate safety issue. Tires are cheap, don't take the chance.
That cobra could easily run in the 10's but he could also turn a blistering 14 second quarter as well. He should short shift all the way through. With the level of torque he has, he should pull with lower RPM's with out a problem. That would go a long way towards keeping it under control.
High Maintenance Racing Team
Run & Gun 2003 - 2013
