Old 01-30-2011, 09:45 AM
289ACE's Avatar
289ACE 289ACE is offline
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
Originally Posted by elmariachi View Post
I have driving experience with both a Cobra and a 458. If you both want to make this fun, safe and fair, my advice is to go to the drag strip and first run a couple of solo passes against the clock, not each other. This will give you both a better sense of how your cars will behave and it will also dampen a bit of the adrenaline and testosterone that will be pulsing through you by not having to stage against each other.
Once you both make a couple passes, compare results and discuss whether or not you feel you can safely race each other. After 2-3 solo timing passes and 1-2 against each other, you should be able to have a safe race that yields some accurate results, with no hardware left lying on the track and no Ferrari black paint on the walls.
"Gimme $500 on the Bandit...er, I mean the 458."
Great Suggestion
Tommy,
Can you get your friend to join in on this thread? He might benefit from the conversations on the safety issues, and he can let us all know the details of his car.
Jay
