Old 01-30-2011, 03:23 PM
GC427's Avatar
GC427 GC427 is offline
Cobra Make, Engine: Superformance, Roush 427R
Blas,
I checked the fuel sending unit wires. The wires are in excellent condition, no shorts at the terminal posts, and no loose connections where connected to the sending unit. Fred (SP0884) mentioned his problem was the voltage stabilizer. Should I replace that next? Is there a simple way to send 10 volts through the fuel gauge first to see if it's working? I haven't traced the wires from the fuel sending unit all the way to the fuel gauge. Are there anymore terminal connections along the way I should check? Is there an in-line fuse in the fuel gauge circuit that may of blown?
Gil. Battle Ground, WA
Gil, SP02047, Roush 427R, Tremec TKO 600 RR, www.CascadeCobras.com
