Old 01-30-2011, 03:46 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Hmmmmm....
Check to see if you have power at the tank sender....Then check to see if you have power at the step-down unit on the drop down fuse panel. (upper left hand corner) Power to step down is a green wire powered thru fuse #10
(The 2nd fuse down on right side fuse bank) #10 also powers the Tach...So if the Tach works, check power to and thru the step down. Keep me posted on what you find...
SPFWiringDiagrams@Comcast.net
