Old 01-31-2011, 08:25 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Madmaxx - That's a good idea to try too. You can use an OHM meter to do this test if you have one...
Gil - Remember to also check the connections on the back of the fuel gauge since the problem started after you hit a few large bumps in the road...could be a loose wire connection there.
SPFWiringDiagrams@Comcast.net
