Old 01-31-2011, 11:15 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
The higher the fuel level, the lower the resistance.
With the key on, connect the two wires at the sender to each other. That should peg the gauge at full. If it doesn't, the problem is in the gauge or wiring. If it does peg the gauge, the problem is probably the sender.
Jim
A Gnat! Quick, get a sledgehammer!
