Old 02-01-2011, 08:57 PM
stiffy stiffy is offline
Default Oils aint oils,,,,,
SAMBO,
Thants the stuff. It was recommended by Aussie Mike for the box and the guy who did the pump.
The pump guy doesn't think you need to run a cooler with his pump
and the synthetic fluid, but I wanted to be sure.
I also replaced the main pulley with a 25% reduction unit, again for the heat issue. All the mods seem to have worked ( last time on the track it was fine ) it still gets hot and the fluid will weap out of the reserviour.
The only issue is that at idle the volts drop.
STIFFY
