Old 02-01-2011, 08:05 PM
GC427's Avatar
GC427 GC427 is offline
Cobra Make, Engine: Superformance, Roush 427R
Default Appears to be the fuel gauge
Blas,
The resistance test across the two terminals on the back of the fuel gauge indicates an OPEN circuit. NO READING whatsoever. It appears the fuel gauge part number is BF2242-03C with Caerbont Automotive LTD above the part number. The voltage reading across the two terminals with the key in the off position is 0.00 volts. With the key in the on position, the voltage reading across the two terminals is 9.86 volts. Looks like the fuel gauge is the problem. I did not check the voltage from each wire connected to the fuel gauge to ground. Do you think it's the fuel gauge?
I tried to respond sooner but could not log-in and kept getting a Database error message: "The Club Cobra database has encountered a problem." Seems to be working now.
Gil
Gil, SP02047, Roush 427R, Tremec TKO 600 RR, www.CascadeCobras.com
