Old 02-02-2011, 01:55 AM
sideshow sideshow is offline
the fiddly bits are the hardest to sort out
most old school auto elects have no ieda and use old poor parts see it many times
just had to work with a pre made fusebox wiring kit from rocket industries which customer supplied and had to mod the back of it so one fuse can be used for something else and pulled on wire gently and it came out
so beware as u all know most sheit comes from china and quality and tightness of crimps are pisspoor
anyway quickest and easiest way is to connect alternator wire thru diodes to turn on the handbrake or low brake fluid light
this way when alt turn on the charge light it turns on the others
if u do have barina brake fluid resevior sensors they have 3 wires
an earth and a brake light wire and an alternator wire
they have diodes in the cap which does it for u
my website
www.sideshowsperformancewiring.com.au
