Old 01-22-2002, 12:37 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
If you can afford new rods, use them. If not a properly reworked set of LeMans will work fine with new bolts. I doubt that you will ever see 6,500 rpm with a stroker, yet alone 7,000 rpm which they will last forever at. This is speaking from experiance. As far as pistons go, JE is the way to go. They will make anything your builder wants for a reasonable price. Nobody makes anything better.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
