Thread: Turkey Pan
Old 02-02-2011, 03:31 PM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Originally Posted by Machiavelli View Post
Ah yes, the much debated "Turkey Pan".
User feedback requested, fuel injected need not respond.
True or False, you tell me - the below pulled from an undisclosed web location.
Turkey pans are one of the most misunderstood engine accessories. Today with all the high tech stuff we undertake, we as a group don't often give credit to the racing people of the 60's. They did something quite unique in getting a sports car with the aerodynamics of a barn door to go 160+ mph.
Doing the Turkey Pan Mathematics
The "Turkey Pan" (cold air box) was one of the reasons that the 427 performed like it did. Doing the math helps us understand why. A hood scoop opening of 2"x10" or 20 sq. in. moving through the air for one mile at 60 miles an hour takes in nearly 8,000 cubic feet of air. Your 427 cu. in. engine, traveling the same speed, turning 2500 rpms is only using 350 cubic feet or so of air. When sealed against the hood with a rubber gasket (which most folks don't like doing because the gasket chafes the paint) forms a high pressure area between 2-5 psi of cold air pressure, depending on how fast you are moving. The excess cold air spills out through the bottom opening, thus cooling the intake manifold and the air charge running through it. It creates "free horsepower" and the only drawback to this is that you must be moving!!
I read a forum post one time where two cobra guys where talking about turkey pans and got a little chuckle when one said "I don't think the turkey pan helps at all." To make such a statement is idiotic at best. "Every" high performance intake system uses cold air under pressure to gain a horsepower and fuel mileage increase!!!
I swear by turkey pans, we are old but it works, Same thing with the cool cans with dry ice or alcohol to avoid bubbling inside the fuel lines. These technologies worked then, why not use them now?
BAsque1
