Old 02-04-2011, 08:40 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Thought it would be nice to post a list of parts usually supplied with a new SPF roller.
I know there are also differences in parts supplied with the Roadster and the SC versions.
Please correct my list if I'm mistaken and post any pieces I my have missed. I will update list.
From the Photos I see:
Parts Provided with Roller:
1 - Upper Radiator Hose
2 - Lower Radiator Hoses
1 – Shifter Boot With Mounting Ring (SCREWS?)
2 – Door Latch Leather Straps
1 – Steering Wheel Center Cap with installed O-Ring
1 – Upper Radiator Metal Hose Section
1 – Lower Radiator Metal Hose Section
1 – Throttle Linkage Assembly
1 – Carburetor Heat Spacer
8 – Radiator Hose Clamps
1 – Rear View Mirror Post, 2 Mounting Bolts & Mirror.
2 – Lift-a-Dot Female Clasps
2 – Tenax Male Fasteners w/2 washers
2 – Oil Pressure Line Block Connection Fittings
2 – Motor Mount Assemblies & Plates (Engine Choice Required)(BOLTING?)
2 – Sidepipe Mounting Brackets (Bolting?)
1 – Shifter (Bolting?)
4 – AN Oil Line fittings (SIZE?)
2 – Caution HOT - Adhesive Backed Stickers for Door Jambs
1 – Caution Windshield - Adhesive Backed Sticker
1 – Superformance Adhesive Backed Plastic Badge
1 – Manufacturers I.D. Aluminum Plate (Mounting?)
1 – Generic Coil Mounting Bracket (Bolting?)
1 - Plastic Oil Pressure Line
2 – Ignition Keys
2 – Fuel Cap Lock Keys
2 – Trunk/Hood Lock Keys
2 - Original style side pipes and headers (BOLTING?)
2 - Standard Clasp Lap Belts (Driver & Passenger Sides)
Also Provided with Roller:
2 – Side Curtains w/ Storage Bag
2 – Top Bows w/ Storage Bags
1 – Convertible Top w/ Storage Bag
1 - Tonneau Cover
1 - Drivers Side - Outside Mirror. (Maybe Dealer Installed?)
Options:
Hardtop.
Leather Steering wheel
What Other Options are available?
Can someone confirm the Following:
What other Bolts/Nuts/ Washers/Screws/etc are Supplied ?
Are the 2 Braided Lines for Oil Cooler or Oil Filter Provided ?
2 – Small Clamps for Heater Hoses Provided?
Is that Touch-up Paint in the can normal? Which Color?
1 - Factory Owners Manual (Small) ?
2 - Glove Box Keys ?
Are Floor mats provided?
Adjustable Drivers seat - Passenger Side Optional ?
Round Tail Lights are Optional ?
Shoulder Harnesses are Optional ?
Is Glove Box is Optional ?
What comes with the transmission Install kit?
SPFWiringDiagrams@Comcast.net
