Old 02-04-2011, 07:47 PM
timsullivan's Avatar
timsullivan timsullivan is offline
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Blaz: Great job itemizing the various parts. See my comments below next to your questions. I have the "Hi-Tech Automotive Pack Kit" listing of individual components and related part numbers --kind of an inventory listing of parts that made up the install list that came with my car as well. In addition, I have the the Superformance Factory Options and Dealer Options order form that was used at the time my car was ordered from the factory. I could probably post those in my gallery if people find the information useful.
I figure I spent around $150 or so, on high quality Grade 8 fasteners that I had to purchase separately from my local Ace hardware.
Parts Provided with Roller:
1 - Upper Radiator Hose
2 - Lower Radiator Hoses --all three are "RH391"
1 – Shifter Boot With Mounting Ring (SCREWS?) --No mounting screws were provided
2 – Door Latch Leather Straps
1 – Steering Wheel Center Cap with installed O-Ring
1 – Upper Radiator Metal Hose Section ---200MM
1 – Lower Radiator Metal Hose Section ---250MM
1 – Throttle Linkage Assembly
1 – Carburetor Heat Spacer
8 – Radiator Hose Clamps
1 – Rear View Mirror Post, 2 Mounting Bolts & Mirror.
2 – Lift-a-Dot Female Clasps
2 – Tenax Male Fasteners w/2 washers
2 – Oil Pressure Line Block Connection Fittings
2 – Motor Mount Assemblies & Plates (Engine Choice Required)(BOLTING?) --Mine were 351W spec with no bolts provided
2 – Sidepipe Mounting Brackets (Bolting?) --No bolts provided
1 – Shifter (Bolting?) --No bolts provided
4 – AN Oil Line fittings (SIZE?) ---AN10
2 – Caution HOT - Adhesive Backed Stickers for Door Jambs
1 – Caution Windshield - Adhesive Backed Sticker
1 – Superformance Adhesive Backed Plastic Badge
1 – Manufacturers I.D. Aluminum Plate (Mounting?) -¬-no mounting rivets or fasteners provide. SPO number needs to be punched into tag
1 – Generic Coil Mounting Bracket (Bolting?)—No bolts provided
1 - Plastic Oil Pressure Line
2 – Ignition Keys
2 – Fuel Cap Lock Keys
2 – Trunk/Hood Lock Keys
2 - Original style side pipes and headers (BOLTING?) ---No bolts provided
2 - Standard Clasp Lap Belts (Driver & Passenger Sides)
Also Provided with Roller:
2 – Side Curtains w/ Storage Bag
2 – Top Bows w/ Storage Bags
1 – Convertible Top w/ Storage Bag
1 - Tonneau Cover
1 - Drivers Side - Outside Mirror. (Maybe Dealer Installed?) ---Mine was already installed by the factory
Options:
Hardtop.
Leather Steering wheel
What Other Options are available? –Polished Stainless Steel Quick Lifts, glove box, expansion tank, coated headers and side pipes, different types of body stripes, passenger side roll bar, race roll bar, passenger side exterior mirror, ashtray, 17” PIN Drive wheels, custom colors, hard top, No Rivets on Hood Scoop or Hood, Passenger seat slides, non-standard “colour” leather seats or dash or door panels or carpets, radiator rock guard, oil cooler rock guard, floor mats, car cover, polished stainless steel Over Riders/Bumperettes, polished stainless steel Roadster bumpers with hoops,
Can someone confirm the Following:
What other Bolts/Nuts/ Washers/Screws/etc are Supplied ? –Very few if any
Are the 2 Braided Lines for Oil Cooler or Oil Filter Provided ? Yes, I was supplied with about 10’ of braided steel hose
2 – Small Clamps for Heater Hoses Provided?—not that I remember
Is that Touch-up Paint in the can normal? Which Color? --Body paint color supplied
1 - Factory Owners Manual (Small) ? --Yes
2 - Glove Box Keys ? --Yes
Are Floor mats provided? --No, optional
Adjustable Drivers seat - Passenger Side Optional ? -Yes
Round Tail Lights are Optional ? I don’t think they are any longer. Not listed on my “Factory Options” order sheet
Shoulder Harnesses are Optional ? I don’t think they are as they were not listed on my “Factory Options” order sheet
Is Glove Box is Optional ? ---Yes
What comes with the transmission Install kit? --Besides the actual original style shifter lever(that bolted to my Tremec trans) nothing. No rear trans mount was provided.
