Old 02-05-2011, 12:53 AM
Zedn's Avatar
Zedn Zedn is offline
Originally Posted by renovationinnov View Post
the guy next door migs boats for a living said to try you feeder rollers that there not to tight / loose
then check your liner & check your allyspool for **** [ his words] on the wire try running a rag over it to keep it clean ' , he said to run a old piece of soft carpet on the spool all the time to remove ally corrsion off the wire [ you don,t know how long it has bben on the shelf
hope this helps rob
Thanks Rob,
Il check it out. I spent some time welding today and im really happy with the result. I am just working on scrap at the moment, but after today i think im ready to start on the car. Its still a bit rough for the first 10mm of the run, but i will check the spools not binding up at the start and slowing the feed. Im getting good penatration at least so appearance doesnt matter too much as i will grind it smooth.
Cheers.
Liam
