Old 02-05-2011, 09:22 AM
JustOne JustOne is offline
Cobra Make, Engine: Unique FIA, 425 Windsor
Whiter,
The Jag Unit that Unique uses is rebuilt by either them or Southern Gear, one of their dealers. Alan and Maurice will spec the rear-end to your suited needs. They built the rear end for my car with a locker and a 3:31 gear ratio as requested. Most of the time I run around on Drag Radials and have never had a problem with the rear end. That said, I do not abuse the IRS by revving the motor up and dumping the clutch. If I get on it from a stand still, I do an off idle start.
As Juan said, Unique builds a very good car, here in America. If you go to their shop you will meet them and their skilled craftsman that work for them.
Justin
