  #21 (permalink)
Old 02-05-2011, 03:15 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I used Ameron Two Pac Epoxy for concrete......used a concrete grinder to run over the floor 100sqm this made the surface beautiful and smooth (if you want the top coat smooth youve got to get concrete smooth first) I then etched it with hydrocloric Acid 4-1 then pressure cleaned it .....I left it for a week then vacuumed before painting... The Ameron Epoxy could be driven on after about 3 days but took probably a month before it was rock hard
