Old 02-05-2011, 06:39 PM
timsullivan's Avatar
timsullivan timsullivan is offline
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default Misc parts for Superformance install...
Blaz: The picture shows the speedometer angle drive which is installed on the back of the speedo and to which you hook up the speedo cable to.
Other items I purchased (besides literally 5 pages of parts for the individual engine parts, bell-housing, clutch, pressure plate, flywheel, throw-out bearing, clutch slave and trans):
• Battery
• 3 Ύ” Hole saw (to cut hole in console for shift lever)
• Heater hose support clamp (mounted on inner fender-well)
• Speedometer cable
• Brake / Clutch fluid (Dot 3)
• Engine motor mounts
• Nose, trunk and side emblems (Shelby/ 427)
• Driveshaft
• Rear trans mount
• Fuel line hose (connection from hard line on chassis to fuel pump)
• Hose: expansion tank overflow to puke tank (“coolant overflow recovery bottle”)
• Floor mats from Finishline
