Old 02-06-2011, 04:58 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by MaSnaka View Post
Is there an adaptor availible that connects the Hurst shift lever to the top loader? And if so where to locate one. Currently my shift lever bolts down from the top and I know the Hurst levers bolt on from the side. I'm looking to change shift levers and trying to avoid any cutting and welding to make it work. An adaptor would be perfect.
Thanks, John
Do you currently have a Ford-style shift handle and you instead want to install a Hurst handle? The Hurst conversion I have from ERA has a Ford handle that bolts down to an ERA-modified Hurst shifter lever in the body. That sounds like what you have now. You would basically have to order a new, stock shift lever from Hurst and dissassemble the shifter and install it and bolt your new handle on.
That's if I understand your question correctly.
