  #59 (permalink)
Old 02-07-2011, 01:30 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Jim,
Can I assume if while leaning on the shifter and you turn the engine off, the box drops into gear as the engine stops?
If that is the case, you most likely have a dragging clutch or a dragging spigot bearing.
Either way the input shaft is not coming to rest as easily as it should.
Gary
