  #66 (permalink)
Old 02-08-2011, 02:32 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by madmaxx View Post
I am not so sure on the physics of the clutch arm pushing on the throw out bearing and in turn deflecting the input shaft causing binding of the pilot bushing is accurate. In fact if you take off your slave cylinder you will find the clutch arm to pilot bearing has quite a bit of movement by design. It is impossilbe to deflect the input shaft by use of the clutch arm so slave cylinder misalignment may result in reduced slave cylinder life it will have not affect on input shaft to pilot bearing / bushing.
Tell him to guess again. I would take a radial runout measurement on your input shaft, id measurement on your bushing/bearing. Obviosuly radial runout should be zero.
That is true.
The throwout fork and bearing come nowhere near the input shaft.
Every manual trans has a snout for the throwout bearing to travel on. The input shaft runs inside the snout.
If there was any contact is this regard you have a clutch that wouldn't disengage at all, and a high pitch squealing noise.
Gary
