Old 02-10-2011, 06:28 AM
Years ago I used the 12 volt positive connection on the COIL and the other lead to ground. That works on standard ignition systems. It does NOT work with MSD ignition. Turns out the MSD can supply as much as four hundred volts to the plus side of the coil. Blew out the timing light in a heart beat....
