Old 02-10-2011, 05:57 PM
blykins blykins is offline
Originally Posted by garry viohl View Post
482 FE with aluminum heads and 35 total timing.
Do you think it will ping? What happens if the air temp goes to 100?
Thanks.
The simple answer is that it depends on a lot more than if the heads are aluminum and how much timing you have in the engine.
Some other things it depends on:
1. Camshaft
2. How close the pistons are to zero deck (quench distance)
3. If the pistons have been hand-worked to remove all sharp edges
4. Chamber design
5. Cam timing
There are LOTS of variables here.
I have ran a 428 FE with Edelbrock heads at a little over 11:1 with 93 octane. That was with 38 degrees total timing. No issues.
So yes, it can be done if all the parts are working well together. It's a little easier in a lightweight car like a Cobra, especially with lower (numerically higher) rearend ratios.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
