Old 02-11-2011, 04:32 AM
blykins blykins is offline
Unfortunately, it's very hard to drive a dyno. The only real amount of tuning that you can do is for WOT and that includes jetting, total timing, etc., trying to find the most horsepower.
That same combination may have a horrible lag or dead spot on the street when you're out driving.
If you can get it close on the dyno, then the best scenario is to get it out and drive it, then tune from there.
One more important fact here is that timing will most likely not be the same from the dyno to the car anyway. MSD boxes can vary up to 5-6° and just because you had the timing set on the dyno doesn't mean that it will be the exact same in the car. This happens all the time to engines that I dyno and send out to the customer. I always advise the customers to recheck the timing once it's in the vehicle.
There are also airflow differences, where on the dyno, air is funneled in through a big hose. In the car, airflow gets in through several different ways and will not be the same volume of flow.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
