Thread: DRB 540 build
Old 02-11-2011, 10:22 AM
Rob. Smith Rob. Smith is offline
Its not so much the thread I was concerned about, more the "gauling" (I think that is the word) that the stainless may do to the alloy, and as Alffie says, if not spot on, they will leak.
Stainless and aluminium does react with each other...something to do with electrolosis.This is relating to sheet and plate metals with a decent surface area. I'm not too sure about threaded fittings. As far as galling, the aluminium will act as a lubricant on the stainless. similar to the zinc/silver based paste stuff ...Goop, nevaseize etc. that you should always use on stainless nuts & bolts. The only downside would be the two different "strengths" of the materials, so if nothing heavy is swinging off the fitting. You shouldn't have a problem.
