Old 02-13-2011, 04:21 PM
Default Why not run a P/S fuel pump as one?
Funfer2 Why not run a clog belt setup with the fuel pump hooked to the back of the P/S pump?? Not sure of what pressure you are looking for but see no problem with this setup. I surp belt would be a better setup than a clog for you need a little slipage to prevent belts popping off or ripping the teeth out of the clogs. I know where to get special pulleys if needed. Rick L.
