Old 02-14-2011, 10:13 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Doug,
No offense, but do it right. Removing those sending units is a small task that you can do in about an hour if you take a couple breaks. A bit of advise if you plan on gluing the naugahyde onto the back of your dash take the time to scuff up the back of your dash especially about 2" in from the edges and paint it. It will make your adhesive hold better and last longer especially if you use some kind of solvent to get the old glue off. 3M green can of spray adhesive works best and its about $13 at lowes.
"Let's roll"
"Be part of Something Good
